Failover – Inverted heartbeats (Local switch disconnected from active and offline agent)
Solved1.93K views19th July 2023Failover
Miguel Obregon [SLC] [DevOps Catalyst]22.20K 25th March 2021 0 Comments
We configured a failover setup following the best practices described in the DataMiner Help [Link]:
We tested the following scenario:
Active and offline agents lose connectivity with a network switch that is used to configure the inverted heartbeats. Acquisition and Corporate networks are still available from active and offline agent.
When the network cable connecting to the switch is pulled out from the active and offline DMA, we noticed the following:
  • In the Alarm Console, a notice will appear, indicating that the heartbeat path is failing
  • The active agent goes offline
  • The offline agent stays offline
After a couple of minutes, the active agent becomes online again.
Checking the FAQ related to failover setups [Link], we could not find this use case. Please could you let us know if the events described above are expected?
DMA version: 10.1.2.0-9866
Ive Herreman [SLC] [DevOps Enabler]14.50K Posted 26th March 2021 1 Comment
Hi Miguel,
My 2 cents, I would define just one inverted heartbeat.
Miguel Obregon [SLC] [DevOps Catalyst] Posted new comment 26th March 2021
Miguel Obregon [SLC] [DevOps Catalyst] commented 26th March 2021
Hi Ive,
Thanks! I will test this configuration and let you know the outcome
