Failover configuration using hostname
Solved1.45K views30th January 2025Agent failover configuration dataminer failover
Edson Alfaro [SLC] [DevOps Advocate]1.76K 30th October 2024 0 Comments
Hi all,
For a failover configuration using hostname, the documentation states that IIS extension “Application Request Routing” must be installed on both DMAs.
Is there any special consideration to configure it after installing it to make our failover work?
Do we have a configuration guide or MOP for it?
Thanks.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th January 2025
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 30th October 2024 0 Comments
Hi Edson,
You don’t need to configure the Application Request Routing.
Dataminer will do this for you (every time a failover takes place).
