Failover Configuration interface name
Solved835 views15th June 2026
8
Stefan Schedletzky [DevOps Advocate]2.84K 11th June 2026 3 Comments
only on one server I have the issue that the names of the interfaces are not correct. Where is this defined in Dataminer? I guess it's an old setting.
Wrong names:
Correct names:
Here you can see the mess up:
But both network interfaces are configured the same.
Stefan Schedletzky [DevOps Advocate] Selected answer as best 15th June 2026
Alberto De Luca [DevOps Enabler] commented 11th June 2026
Hi Stefan – not a full answer – but I'd check NetworkAdapters setting in DataMiner.xml – and compare with step 9 here on this page:
https://docs.dataminer.services/dataminer/Administrator_guide/Failover/Configuring_Failover/Failover_configuration_in_Cube.html
I'll follow the thread to get more insights
HTH
Stefan Schedletzky [DevOps Advocate] commented 11th June 2026
Not helping at all 🙁
Kinda hard to give more insight without knowing your deployment – but I'll try harder – do you happen to have any NIC teaming defined (lbfoadmin.exe to check) ? Names are either gonna come from the host of from a DM config – checking the different layers is the only thing I can suggest I'm afraid ..
Nils Hoven [DevOps Advocate]1.83K Posted 11th June 2026 3 Comments
Hi Stefan,
I have the same issue in our DMS occasionally, usually after performing a system upgrade. The interface names are the ones configured in the Windows environment on the hosting machine; DataMiner is just reading them out and uses the names in this context. Anyway, my solution to the issue is actually to reboot the machine that is having the issue (in your case GER-DMA01-M), and this should fix it.
Not the most sophisticated way to resolve this, but it was enough for me in the past... 😉
Hope this helps!
Nils Hoven [DevOps Advocate] Posted new comment 15th June 2026
Hi Nils,
I will give it a try next week to reboot the machine. Thanks for sharing your experience 🙂
Stefan Schedletzky [DevOps Advocate] commented 15th June 2026
Works perfectly!
Nils Hoven [DevOps Advocate] commented 15th June 2026
Great to hear! 😀
