Failed to compile after replacing class lib with nuget package
Solved1.70K views31st March 2023NuGet
8
Ana Pinho [SLC] [DevOps Member]1.42K 30th March 2023 0 Comments
I'm having an interesting issue.
After replacing the dll referenced on my solution by the respective NuGet packages, I'm having issues with the compilation of the QActions.
On the precompiled QAction, it seems that reference for the nuget got lost. However, they are on the solution:
On my local DMA, I don't have this issue, everything works fine.
Any guesses?
Thanks!
Ana Pinho [SLC] [DevOps Member] Selected answer as best 31st March 2023
Jorge Dias [SLC] [DevOps Enabler]5.35K Posted 31st March 2023 0 Comments
Hi Ana,
When that library was put on a nuget package the namespaces were changed to comply with the nuget naming convention.
So it changed from Skyline.DataMiner.Library to Skyline.DataMiner.CommunityLibrary.Utility.
Jorge Dias [SLC] [DevOps Enabler] Answered question 31st March 2023
