Extract data from a specific devices on Dataminer
Solved2.87K views19th July 2023
Javier Gordon30 22nd March 2021 0 Comments
Good afternoon team,
They could tell us if there is a way to extract data / tables from specific devices that are kept in the local dataminer database, either by means of a script or something similar.
Our dataminer version is 10.0.0.0-9517-CU6.
Regards
Leander Druwel [SLC] [DevOps Member]2.10K Posted 23rd March 2021 0 Comments
It could be important to understand the reason why you want to retrieve information from the database tables.
DataMiner offers many different interfaces to retrieve stored data, and our recommendations will always be to use these interfaces if any data needs to be consulted through any third-party application.
More information on:
https://help.dataminer.services/dataminer/#t=DataMinerUserGuide%2Fpart_3%2FDataminerSystems%2FDataMiner_interfaces.htm
Edson Alfaro [SLC] [DevOps Advocate]1.76K Posted 22nd March 2021 0 Comments
Hi Javier,
I totally recommend to start using the New Dashboards app to look for specific information  from Dataminer, a very useful tool is the queries, so you can enroll to the course and start playing around with it.
Queries
Thanks.
Edson Alfaro [SLC] [DevOps Advocate] Answered question 22nd March 2021
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 22nd March 2021 1 Comment
Hi Javier,
Another options (from DataMiner 10.2.0/10.1.1 onwards) it is possible to offload data to a file in the local system cache folder instead of to an offload database:
You can find more information in the DataMiner Help:
  • Offload database (File)
  • Configuring Data Offloads
The CSV files are stored in C:\Skyline DataMiner\System Cache\Offload
Miguel Obregon [SLC] [DevOps Catalyst] Posted new comment 22nd March 2021
Miguel Obregon [SLC] [DevOps Catalyst] commented 22nd March 2021
I forgot to mention that you could also use the web service API:
More information in Dojo:
https://help.dataminer.services/WebServices/#t=SLC_UM_DataMinerWebServicesWS_part_2WS_part_2.htm
Roger Bijos [SLC] [DevOps Member]455 Posted 26th March 2021 0 Comments
Edgar & Javier – Going into a distributed DB to try and query a consolidated list of elements and or parameters may poses its challenges.
Have you considered using our WebServices (DataMiner Web Services API reference guide) or generating such reports directly in our Dashboards (DataMiner Dashboards – DataMiner Dojo)module? I would strongly advise considering this route.
A similar use case is the combination of “Profiles” as Mediation layer, in combination with Dashboards.
Let’s say you have different network devices such as Alcatel & Cisco Switches and you want to display information from both vendors in the same dashboard.
Roger Bijos [SLC] [DevOps Member] Answered question 26th March 2021
