Export a file to a local machine folder using automation script
Solved1.05K views30th September 2024
Paul Lee [DevOps Member]665 18th June 2024 3 Comments
I have a file from a DMA that needs to be exported to local machine via automation script.
My first option was to write the script to email the file but it did not seem to work as it seems there is an issue with the server’s smtp settings. So I was wondering if it is possible to export the file to a dedicated local machine folder.
Could you please advise if it is possible to do it via automation script?
Thanks
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th September 2024
Miguel Obregon [SLC] [DevOps Catalyst] commented 18th June 2024
Hi Paul,
Can you double check the comment in your initial question:
https://community.dataminer.services/question/reaching-a-file-in-another-dma-by-automation-script/
And let us know if updating the SMTP settings solve the issue?
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th August 2024
Hi Paul,
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th September 2024
As this question has now been inactive for a long time, I will close it. If you still want more information about this, could you post a new question?
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 18th June 2024 0 Comments
Hi Paul,
You can achieve this through the Download Button with an interactive automation script.
https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Utils.InteractiveAutomationScript.Components.DownloadButton.html?q=DownloadButton
*Note, this seems to require DataMiner version 10.3.7 (or later).
