Entered wrong DMA ID while installation
Solved2.20K views7th June 2021
Jeyaram Sumanthiran30 6th June 2021 0 Comments
Hello Team,
I am in the process of installing the DM software in the fresh server. While installing the DM software I have entered the wrong DMA ID. Is there any option to change the DMA ID to proceed with the further installation and licensing? or should I need to remove the software and reinstall?
Jeyaram Sumanthiran Selected answer as best 7th June 2021
Gellynck Jens [SLC]2.72K Posted 7th June 2021 2 Comments
You could also change the ID attribute of the <DataMiner> tag inside C:\Skyline DataMiner\DataMiner.xml. After restarting DataMiner (with SLTaskbarUtility) a new Request.lic file will be generated (which will then allow you to request a license).
Jarno Lernou [SLC] [DevOps Enabler] commented 7th June 2021
Is this approach as safe as uninstalling and installing again?
Gellynck Jens [SLC] commented 7th June 2021
Assuming your DMA is still in a cleanly installed state (so you haven’t created any elements, didn’t cluster it with other agents,…), it should be safe (and much faster).
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 7th June 2021 0 Comments
Hi Jeyaram,
Since you will need to generate again the request file (request.lic) with the correct DMA ID, I believe the best option is to remove and install again DataMiner.
In DataMiner Help you will find the steps to uninstall DataMiner:
Uninstalling a DataMiner Agent
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 7th June 2021
