Element Replication Scenario: should a CUBE client have comms to both DMA1 and DMA2?
Solved658 views1st October 2025adl2099 element replication replication
Alberto De Luca [DevOps Enabler]5.36K 30th September 2025 0 Comments
Hi Dojo - follow up from other replication questions, such as
https://community.dataminer.services/question/ports-for-element-replication/
and
https://community.dataminer.services/question/element-replication-which-port-has-to-be-enabled-if-firewalls-are-present/
I understand port 443 &/or port 8004 can be used between the DMAs.
Scenario: running CUBE from a dedicated Azure VM, connecting CUBE to "DMA-X" to configure an element replication, where the source element is on "DMA-Y" (DMA-X & DMA-Y are using the same version and have the same protocol for the replication to happen).
DMA-X   <----------- element replication--------------->  DMA-Y
{CUBE client VM connected to DMA-X}
If I run CUBE from an Azure VM (sort of secured jump-host),
is it sufficient to have communication from the client VM to DMA-X?
I was expecting that the data for the replicated element would flow only between the DMAs, but from this page it seems that while configuring element replication, the CUBE client must be able to connect to source DMA too: is it an old requirement or is it still the case?
https://docs.dataminer.services/dataminer/Operator_guide/Elements/Working_with_elements/Replicating_elements.html?q=While%20you%20configure%20element%20replication
Alberto De Luca [DevOps Enabler] Selected answer as best 1st October 2025
Bert Buysschaert [SLC] [DevOps Advocate]5.02K Posted 1st October 2025 1 Comment
Hi Alberto,
It is still a requirement for Cube to have direct access to both DataMiner agents.
You first log in on the DMA where you want to create the replicated element (1), and during the configuration Cube will connect to the DMA where the source element is located (2), using the provided credentials, in order to retrieve the list of elements to choose from. When the element is configured, SLProtocol on the DMA with the replicated element will connect to SLNet on the source DMA (3) to subscribe on the parameter changes.
Alberto De Luca [DevOps Enabler] commented 1st October 2025
Hi Bert,
Thanks for the clear diagram and the speedy confirmation – much appreciated!
Marking as solved
