Element Replication
Solved1.49K views2nd May 2024
Andy Fairhall [SLC] [DevOps Member]244 1st May 2024 1 Comment
When replicating an element via dataminer.services, do the source and destination DMS’s need to run the same DM versions?
Ben Vandenberghe [SLC] [DevOps Advocate] Posted new comment 2nd May 2024
Ben Vandenberghe [SLC] [DevOps Advocate] commented 2nd May 2024
Just a note on the side here – element replication does not run via dataminer.services, it is peer to peer between two DMAs (typically each in another DMS – although it can be between any two DMAs). And as Miguel pointed out, both source and destination DMAs need to be the same version (although I believe that it doesn’t necessarily mean that it would not work if they are not), and both need the same driver (associated with the element that is being replicated).
Miguel Obregon [SLC] [DevOps Catalyst]23.68K Posted 1st May 2024 0 Comments
Hi Andy,
According to DataMiner Docs, source and destination must have the same DM version:
The source and replication DMA must use the same DataMiner version. In addition, the replication DMA has to be able to set up a connection towards the source DMA.
Hope it helps.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 2nd May 2024
