Element Properties Not removed from Element General Parameters Table after Property is Deleted
Solved1.71K views13th July 2023Element General property properties
Michael Wells [SLC] [DevOps Member]502 4th August 2022 0 Comments
Is it normal that if you create an element property, and if you set that element property to a value, and then you delete that element property, that the property would still be displayed in the element’s General Parameters Properties Table 65019 even though it has been deleted as a property and no longer appears in the element custom properties dialog?
Restarting the element doesn’t remove the deleted property.
Restarting dataminer doesn’t remove the deleted property.
Duplicating the element doesn’t remove the deleted property.
Closing and restarting Cube does not remove the deleted property.
Clearing the Cube cache with Cube XBAP Cache does not remove the deleted property.
Creating a brand new element fixes the issue and does not show the deleted property.
Ive Herreman [SLC] [DevOps Enabler]14.81K Posted 5th August 2022 0 Comments
Hi Michael,
I believe it’s best to raise a software issue task for this.
