Element display Grey and Offline
Solved818 views5th July 2023
Ganesh Supurmaniam14 28th April 2023 0 Comments
Noticed this issue one of the elements for a specific location turns out to be grey.
Checked the network connectivity to able to reach the monitored ELEMENT.
Tried multiple times to stop and activate the driver yet shows offline
Need advice how get this element back online,tq
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 28th April 2023 1 Comment
Hi Ganesh,
Based on the screenshots, it seems that your element is working as expected and values are visible.
If the element is gray, even though KPIs are visible in the element, then it’s likely that you don’t have an alarm template assigned to your element.
Can you please verify if an alarm template is assigned?
Ganesh Supurmaniam commented 28th April 2023
Thanks Ive for assistance,
Noticed another removed the alarm template from logs.
Added back the alarm template, the element is back online.
