Element Alarm State
955 views2nd July 2026
Stefan Schedletzky [DevOps Advocate]2.84K 2nd July 2026 0 Comments
how does this alarm get triggered?
I had to restart now the element to clear the alarm. It was not activated in the alarm template and even completely excluding it doesn't help.
Bert Vandenberghe [SLC] [DevOps Enabler] Answered question 2nd July 2026
Miguel Obregon [SLC] [DevOps Catalyst]24.02K Posted 2nd July 2026 0 Comments
Hi Stefan,
If you already double-checked that this general parameter is not monitored in the alarm template, then there is likely something else causing this behavior.
I would suggest contacting DataMiner Support (support@dataminer.services) so they can perform a more thorough investigation.
Hope it helps.
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 2nd July 2026
Bert Vandenberghe [SLC] [DevOps Enabler]10.12K Posted 2nd July 2026 2 Comments
Hi Stefan,
Note that those general parameters (=parameters added by DataMiner to each element independent of the connector it is using) are a little bit more hidden away.
As indicated on the screenshot here below, those parameters are located under a special page 'General parameters' located at the very bottom of the navigation panel of the element card.
Also, in the alarm template those general parameters are not being shown by default. You need to click on the selection button at the top to select 'All parameters (protocol + general)' and then you will be able to see those general parameters towards the end of the list.
If you activate monitoring on this specific parameter 'Element alarm state', and you generate a major alarm when this parameter goes to the value 'Major'. Then you basically lock the alarm.
Imagine that a normal parameter goes into major alarm, then the element state will go into major state as well. So this means that this parameter will also generate a major alarm. Then if the original alarm clears, your element will remain in alarm forever because that alarm on the element state will never clear... I think you have to be very careful when activating alarming on this parameter, unless you want this kind of behavior.
Bert
Bert Vandenberghe [SLC] [DevOps Enabler] Posted new comment 2nd July 2026
Stefan Schedletzky [DevOps Advocate] commented 2nd July 2026
Hi Bert, the problem is I haven't enabled it. Also excluding this parameter hasn't helped (it was NOT activated). After a restart it was gone. But the alarm shouldn't have appeared in general, because it was never enabled.
Bert Vandenberghe [SLC] [DevOps Enabler] commented 2nd July 2026
That's strange… Then I don't immediate have an explanation for this as well. Support can be contacted to dig a bit deeper and investigate how this alarm was generated.
