Edge WebView2 component is not installed
Solved1.37K views4th May 2023
Baptiste Pattyn [SLC] [DevOps Advocate]5.85K 4th May 2023 1 Comment
Hi
I am trying to connect to an agent running version 10.3.5.0-12938 through Client Test Tool but I get the following error:
Does anyone know what I could do to solve the problem?
Baptiste Pattyn [SLC] [DevOps Advocate] Selected answer as best 4th May 2023
Arunkrishna Shreeder [SLC] [DevOps Enabler] commented 4th May 2023
Hi Baptiste, perhaps you need to install this ?
https://developer.microsoft.com/en-US/microsoft-edge/webview2/#download-section
Bert Buysschaert [SLC] [DevOps Advocate]5.07K Posted 4th May 2023 0 Comments
On a DataMiner server, the WebView2 runtime will typically not be installed out of the box. You can grab the Evergreen Bootstrapper or Standalone installer from here: WebView2 - Microsoft Edge Developer
