DynamicUnits trending and alarm values behavior
Solved562 views6th November 2025
Stefan Schedletzky [DevOps Advocate]2.48K 27th August 2025 0 Comments
I have a network parameter in a table and I'm not 100% sure about the DynamicUnits.
Parameter:
Alarms:
Trending:
Do I need to add DynamicUnits tag to the parameter? Or should I recalculate the parameter to Mbps and set this as <Units>?
Michiel Vanthuyne [SLC] [DevOps Advocate]4.79K Posted 28th August 2025 3 Comments
Hi Stefan,
Good to see you were able to solve the problem by recalculating the value.
As a follow-up, I believe you should get the dynamic units without recalculation or explicitly defining the <DynamicUnits> tag for kbps units if you are using DataMiner 10.4.0 [CU10]/10.5.0/10.5.1 or newer. Did it automatically scale in the parameter display? Is there a DynamicUnits option in the softlaunchOptions.xml on your DataMiner system?
Stefan Schedletzky [DevOps Advocate] Posted new comment 28th August 2025
Stefan Schedletzky [DevOps Advocate] commented 28th August 2025
Hi Michiel,
softlaunch is enabled. It was more like alarm values have to be in kbps and trending was shown in kbps. This has changed now. The dynamic units itself in the table was working fine also before.
Michiel Vanthuyne [SLC] [DevOps Advocate] commented 28th August 2025
Hi Stefan, I see we have a task on our backlog to also use the dynamic units in trending. This means that for now, it is the expected behavior that in trend graphs, the base unit is displayed.
Hi Michiel,
good to know that there is a change in plan, would make the life much easier 🙂
