Duplicating a element in another dma with C#
Solved2.22K views22nd April 2025Automation IDma
João Azevedo518 3rd October 2024 3 Comments
Hello everyone, can someone help with the following error?
(Code: 0x80004003) Skyline.DataMiner.Net.Exceptions.DataMinerException: Array cannot be null.
Parameter name: bytes —> System.ArgumentNullException: Array cannot be null.
The code i’m using is this:
try
var dms = engine.GetDms();
var newElement = dms.GetElement(“SmartWifi Alarm Collector”);
IDma dma = dms.GetAgent(agentid);
newElement.Duplicate(“SmartWifi Alarm Collector – BKP2”, dma);
catch
throw;
With this code i can access the agent, get all the info, but when i try to duplicate a element from another agent into it, i get the error listed above.
João Azevedo Selected answer as best 22nd April 2025
Davor Joleski [DevOps Enabler] commented 4th October 2024
Duplication Method Parameters: Check the Duplicate method’s implementation. Ensure that the parameters you are passing (“SmartWifi Alarm Collector – BKP2″ and dma) are valid and that there’s no underlying assumption that might lead to a null reference.
catch (Exception ex)
Console.WriteLine($”Error: {ex.Message}”);
throw; // Optionally rethrow or handle it differently
try this to your code where ever is stoped i think
João Azevedo commented 4th October 2024
Hello Davor, i think everything is right, the Duplicate method requires a (string name, IDma dma), i’m passing that IDma and if i try to access the data inside it i can and i can see the data, but if i try to use that IDma to set as a value needed by Duplicate method, i get the error above. Maybe it’s a bug?
Hi João,
Pedro Debevere [SLC] [DevOps Enabler]3.46K Posted 9th October 2024 4 Comments
Hi João, can you take an export of the element you’re trying to duplicaate and send the resulting dmimport package to support.data-acquisition@skyline.be (together with the full stack trace) so we can have a look at what the issue might be?
João Azevedo commented 9th October 2024
Hi Pedro, im trying send a email to that address with the required information but im getting the following error: “550 5.0.350 One or more of the attachments in your email is of a file type that is NOT allowed by the recipient’s organization.” and the only attachment in the email is the export file of the element, i have tried put it in a .zip file but still getting the same error. Would there be a specific way to send that information?
Pedro Debevere [SLC] [DevOps Enabler] commented 11th October 2024
Hi João, I see, in that case can you send an email to techsupport@skyline.be? Our support team will then provide a secure link where you can upload any necessary files for further analysis. When reaching out, please describe the issue in detail, including the steps taken and any error messages (like the ones you shared here). In the mail, you can also link to this Dojo question.
João Azevedo commented 11th October 2024
Hi Pedro, o have sent the email as per guidance. Thank you!
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th January 2025
A quick update on this: This issue has been resolved, and the fix will be included in the next update of the class library.
Davor Joleski [DevOps Enabler]743 Posted 6th October 2024 1 Comment
As i searched it should work hmm,i don’t know
João Azevedo Posted new comment 7th October 2024
João Azevedo commented 7th October 2024
Yeah, maybe its a bug, but i cant confirm it.
