DMA Connection Issue
Solved1.31K views4th July 2023
Manideep Panabaka [DevOps Member]36 31st May 2023 1 Comment
Hi Community,
Installed DMA in my local machine (Latest Windows Server) and it's up and running in the background too (as second below image shows). But I can't be able to connect either from the browser or cube. Showing that Dataminer is not running.
Arunkrishna Shreeder [SLC] [DevOps Enabler] commented 1st June 2023
You can double check if you performed the installation correctly as per https://docs.dataminer.services/user-guide/Getting_started/Installing_a_DMA/Installing_DM_using_the_DM_Installer.html.
Daniel Martinez [DevOps Enabler]144 Posted 1st June 2023 0 Comments
You can check DataMiner logs to troubleshoot where you have the problem. Maybe SLDataMiner, SLDMS or SLConnectivity give you more information about the problem. As you can't connect via Cube, you would need to check logs on the server folders C:\Skyline DataMiner\logging.
