DMA Connection Issue
Solved1.62K views4th July 2023
Manideep Panabaka [DevOps Member]36 31st May 2023 1 Comment
Hi Community,
Installed DMA in my local machine (Latest Windows Server) and it's up and running in the background too (as second below image shows). But I can't be able to connect either from the browser or cube. Showing that Dataminer is not running.
Arunkrishna Shreeder [SLC] [DevOps Enabler] commented 1st June 2023
You can double check if you performed the installation correctly as per https://docs.dataminer.services/user-guide/Getting_started/Installing_a_DMA/Installing_DM_using_the_DM_Installer.html.
Mykyta Deyneha [SLC]75 Posted 31st May 2023 0 Comments
There are a lot of processes down including SLElement, SLAutomation. This already indicates that your local DataMiner agent is not running correctly. There is a lack of information here to properly answer your question as there could be many answers possible. You can try a restart of the DataMiner agent but I cannot guarantee you being able to connect to the DMA afterward as there could be some issue preventing the DMA from working correctly and therefore a restart can be not enough.
