Disable Correlation Rule or Automation Script with Visio Shape
Solved2.25K views14th July 2023
Michael Wells [SLC] [DevOps Member]502 9th June 2022 1 Comment
We want to use a toggle button shape in Visio to enable/disable an correlation rule and/or an automation script to prevent it from running.  Is this possible to do with a Shape Data Field to use it to either enable/disable the correlation rule, or to "block" the automation script from running?
Nils Hoven [DevOps Advocate] commented 20th December 2022
Hi Michael,
since we are trying to find a way to solve exactly this issue, I quickly wanted to ask if you succeeded in any way. Thanks!
Gellynck Jens [SLC]2.73K Posted 10th June 2022 1 Comment
Hi Michael,
I don't know of a way to disable correlation rules through Visio, a workaround could be to start a script that enables/disables the correlation rule. For this, you can use the UpdateCorrelationRuleMessage (set the Type to Update, fill in the RuleDefinition with the correlationrule ID and use the Enable property to determine if the rule is enabled or disabled).
I don't think there's a way to prevent a script from running. You could work around this by creating a script parameter that indicates if the script is enabled/disabled. For example:
Nils Hoven [DevOps Advocate] commented 13th December 2022
We are trying to do the same (use a shape to trigger an automation script to disable a correlation rule). Is there some sort of template for the UpdateCorrelationRule message that we need to send? I would be really happy about some example and a hint how to implement this. Thanks!
