DIS Suggested Lists Not Appearing in Visual Studio 2022
Solved1.86K views9th August 2024DataMiner Integration Studio DIS installation Visual Studio
Johannes Boshoff [DevOps Member]450 7th August 2024 0 Comments
Good morning.
I am new to DIS. I have been working through the online training. In one of the sections "Data Ingest and Control Plane Development: Concepts" it is shown on the screen that DIS suggests options for the type field after the snippet is added for example
<Measurement>
<Type>(dropdown with options)</Type>
</Measurement>
On my setup however I do not receive any options, so I'm not sure if I perhaps missed a configuration step somewhere? I could also not do the same as what was showed in the video where I click on File->New->File as I do not have the option Dataminer under general, I could do this by selecting a new project and then selecting DataMiner Connector Solution which up until now gave me the same result as seen in the video so I did not think much of it.
Here is an example of what is shown in the video
And then what I see
My options for "new" files
I also read in previous questions allot of times it was due to the NuGet packages not configured correctly, I had a look at mine and they do look correct from my untrained viewpoint, picture for reference.
Michiel Vanthuyne [SLC] [DevOps Advocate] Answered question 9th August 2024
Edib Šupić [SLC] [DevOps Enabler]2.55K Posted 7th August 2024 2 Comments
Hi Johannes,
In order to see suggestions just press ctrl + space in appropriate places, note that not everything has suggestions.
As for the templates. DIS doesn't come with File level templates, only with Project level templates, which you have. DIS changes fast and some features might not be available anymore or might look different but do the same thing(as is case here), it might be the case that File level templates existed in the past, but they were replaced in favour of Project level ones.
Keep in mind that neither of these are DIS specific things, rather Visual Studio features. If my suggestions don't work for you I would suggest as next step to make sure Visual Studio is configured properly and that these VS features work for other types of projects/templates.
Let me know if I can help you with anything else,
Cheers
Timothy Van Poucke [SLC] [DevOps Advocate] Posted new comment 7th August 2024
Johannes Boshoff [DevOps Member] commented 7th August 2024
Good morning Edib. Thank you for the well explained response!
Timothy Van Poucke [SLC] [DevOps Advocate] commented 7th August 2024
As you are new to DIS you might not know about the Ctrl+k+x shortcut (to be used in an xml file). This also a very handy one, it gives you access to all sorts of snippets eg: basic tables, snmp tables, different parameters,… If you never used it I can highly recommend it 🙂
