DIS Error trying to publish an automation script
Solved2.53K views20th January 2023Automation script solution DIS
7
Bruno Dias [SLC] [DevOps Member]2.39K 13th January 2023 0 Comments
I'm using DIS on VS2017 to develop an automation script from scratch.
I used the following option to create an Automation Script solution and just added some code.
As soon as I try to publish on my DMA I'm getting the following error:
System.MissingMethodException:
Message="Method not found: 'System.Collections.Generic.IEnumerable`1<System.ValueTuple`2<System.String,System.String>> Skyline.AppInstaller.AppPackageAutomationScriptBuilderHelper.ExtractAssemblies(Byte[], System.Collections.Generic.IEnumerable`1<System.String>)'."
Source="SLDisCompiler"
StackTrace:
at SLDisCompiler.PackageBuilder.AutomationScriptPackageBuilder.CreatePackage()
at SLDisCompiler.PackageBuilder.AutomationScriptPackageBuilder.Build()
at Skyline.VSX.ProtocolEditor.Margin.PublishDropDownButton.<>c__DisplayClass20_0.<PublishAutomationScript>b__2(DoWorkEventArgs a)
at SLDisCommon.Tools.Tools.<>c__DisplayClass46_0.<RunInBackground>b__0(Object a, DoWorkEventArgs b)
at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
This error still shows up when I comment all the code, so should be some setting on DIS that is raising it. Can anyone please advise?
Bruno Dias [SLC] [DevOps Member] Selected answer as best 20th January 2023
Pawel Bochenek [DevOps Member]736 Posted 14th January 2023 1 Comment
Hi Bruno,
Looks like problem with the Skyline.AppInstaller class, which is one of the packages in the Dataminer Class Library. I had a similar issue in VS 2019 some time ago and fixed it by re-generating the Class Library Code: in Visual Studio solution -> Extensions -> DIS -> Automation Script -> Generate Class Library Code.
Bruno Dias [SLC] [DevOps Member] Posted new comment 18th January 2023
Bruno Dias [SLC] [DevOps Member] commented 18th January 2023
Pawel, thank you for your input, however, selecting that option, doesn’t yield any result in my case.
I’m using an automation script solution by the way.
