DIS Automation script solution dll references
Solved2.53K views16th April 2021Automation script solution DIS
Philip Argent [DevOps Advocate]1.07K 15th April 2021 0 Comments
Hi, I'm just looking at the automation script solution in the last version of DIS, I've used the protocol equivalent for a while.
I see the AutomationScript_ClassLibrary under internal already has a reference to the Newtonsoft.Json.dll, and I can reference the same Newtonsoft.Json.dll against the script cs so it don't complain about a missing reference, but when it's uploaded it adds a dll ref of my local copy, which isn't in C:\Skyline DataMiner\ProtocolScripts\.
Is there an option coming out to add the reference so it doesn't do this (or another way), like in the protocol solution, under the edit script dropdown to the left of the Exe tag?
As a workaround I've added the dll to C:\Skyline DataMiner\ProtocolScripts\ on my local machine, and referenced it there.
Gelber Mahecha [SLC] [DevOps Enabler] Answered question 15th April 2021
Alberto De Luca [DevOps Enabler]5.36K Posted 16th April 2021 0 Comments
Thanks for the tips - I was indeed wondering what was the best way to make it point to the DMA where we connect.
Would there be an option for customers too, at some point, to have a local DMA together with DIS?
