Dataminer RTE ImportThread issue.
Solved984 views23rd January 2024
Fery Andita60 22nd January 2024 0 Comments
Please can you help me in determining what does the following mean? & is it a problem?
‘Thread problem in SLDataMiner.exe: ImportThread for bc68e095-b2ad-4e0a-8967-36681f68ccc9.dll’
Many thanks,
Fery.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 23rd January 2024
Jan Vanhove [SLC] [DevOps Member]1.23K Posted 22nd January 2024 1 Comment
Hi Fery,
This would mean somebody on your system did an element export/import.  The RTE you see means that importing the element takes a long time (more than 15 minutes).  If this RTE remains there it would mean the import is blocked.
Reasons why it can take a long time: a lot of performance or alarm information that needs to be imported.  Or the element config is rather large.
If this RTE would remain, it will be necesarry to analyze a dump of the SLDataMiner process.
Regards
Fery Andita commented 22nd January 2024
Thank you so much for your reply Jan, much appreciated.
Kind regards,
