Dataminer on Nutanix Virtual Machine
Solved1.55K views25th July 2023
MOHAMMED SAFRI MAHMUD42 1st June 2023 0 Comments
Hi All, I wish to explore the Dataminer deployment over virtual machine (VM).
I'm currently operating Nutanix AHV 6.12 LTS virtual machine in my facility.
Would you be able to advice what are the requirements to do so?
MOHAMMED SAFRI MAHMUD Selected answer as best 25th July 2023
Bruno Dias [SLC] [DevOps Member]2.39K Posted 1st June 2023 1 Comment
Hi Safri,
You can see the system requirements on this DM Docs page: DataMiner Compute Requirements | DataMiner Docs
MOHAMMED SAFRI MAHMUD Posted new comment 9th June 2023
MOHAMMED SAFRI MAHMUD commented 9th June 2023
Hi Bruno, thanks for responding. I was actually questioning if the Dataminer system can work on specific VM system (Nutanix AHV 6.12 LTS virtual machine). Seeking your expertise input. Thanks.
