DataMiner not starting, SLDatagateway errors preventing it from starting up.
Solved2.33K views12th August 2023
ryan yahia900 3rd August 2023 1 Comment
Hello all,
One of our DNMAs in our cluster is in a disconnected state and can't start up. In the SLDatagateway.txt logs I can see that we have these messages. Is there any where I can look to fix this issue?
Many thanks,
Ryan
2023/08/03 14:11:00.556|SLDBConnection|SLNetConnection|INF|0|1|Could not connect with SLNet.
(Code: 0x800402B8) Skyline.DataMiner.Net.Exceptions.DataMinerCommunicationException: Problem communicating with ipc://slnetipc/SLNetService: Failed to connect to an IPC Port: The system cannot find the file specified.
---> System.Runtime.Remoting.RemotingException: Failed to connect to an IPC Port: The system cannot find the file specified.
Server stack trace:
at System.Runtime.Remoting.Channels.Ipc.IpcPort.Connect(String portName, Boolean secure, TokenImpersonationLevel impersonationLevel, Int32 timeout)
at System.Runtime.Remoting.Channels.Ipc.ConnectionCache.GetConnection(String portName, Boolean secure, TokenImpersonationLevel level, Int32 timeout)
at System.Runtime.Remoting.Channels.Ipc.IpcClientTransportSink.ProcessMessage(IMessage msg, ITransportHeaders requestHeaders, Stream requestStream, ITransportHeaders& responseHeaders, Stream& responseStream)
at System.Runtime.Remoting.Channels.BinaryClientFormatterSink.SyncProcessMessage(IMessage msg)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Skyline.DataMiner.Net.ISLNet.HandleMessages(ConnectionToken token, DMSMessage[] inputMessages)
at Skyline.DataMiner.Net.LegacyRemotingConnection.TransportSpecificHandleMessage(ConnectionToken tok, DMSMessage[] msgs, Int32 timeout)
at Skyline.DataMiner.Net.LegacyRemotingConnection.TryActionOnUris(Action action)
at SLCassandraClassLibrary.DBGateway.SLNetConnection.AttemptToConnect(String reason)
at SLCassandraClassLibrary.DBGateway.SLNetConnection.Connect(String reason, Boolean forceSetDataMinerRunning)
2023/08/03 14:11:00.556|SLDBConnection|SLDBConnection|INF|0|1|Setting up connection to SLNet (Initial connection)
2023/08/03 14:11:00.703|SLDBConnection|SLNetConnection|INF|0|1|Could not connect with SLNet.
Alberto De Luca [DevOps Enabler] Edited comment 12th August 2023
Alberto De Luca [DevOps Enabler] commented 12th August 2023
Wondering is if this might be of help:
https://answers.microsoft.com/en-us/windows/forum/all/failed-to-connect-to-an-ipc-port/38c3fe8b-e57b-4d03-a7a2-a426380380b5
Indeed, in the case of a DMA, I’d expect that most of these inter-process communication ports would be the ones for NAS/NATS services, as suggested in Ive’s answer
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 3rd August 2023 0 Comments
Hi Ryan,
A couple of things to check:
  1. Are there any more errors in the SLErrors.txt log file?
  2. Are there any more errors in the SLDataminer.txt log file?
  3. Are the NAS and NATS services shown as running in the Windows task manager (on the services tab page)?
  4. Does the SLCloud.xml (c:\skyline dataminer\slcloud.xml) file contain the correct dataminer server IP address?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 10th August 2023
