DataMiner northbound alarming to external system via HTTP
22 views53 minutes agoalarms HTTP north-bound
Jörg Knesebeck [DevOps Enabler]446 2 hours ago 0 Comments
Hi all,
we are looking for a way to forward alarms to an external system via HTTP as soon as they occur.
Basically, we are looking for something similar to DataMiner northbound SNMP traps, but using HTTP POST instead. The receiving system would provide an HTTP endpoint to which DataMiner should send the relevant alarm information.
Our current idea is to use an alarm-triggered Correlation Rule that launches an Automation Script. The script would then send the HTTP POST either directly or via a Connector.
My questions are:
  1. Is this a reasonable approach, or would you recommend a different solution?
  2. Does DataMiner already provide a standard mechanism, solution, or Connector for HTTP-based northbound alarm forwarding?
Thanks,
Jörg
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 53 minutes ago
Miguel Obregon [SLC] [DevOps Catalyst]23.98K Posted 53 minutes ago 0 Comments
Hi Jorg,
As far as I know, DataMiner does not provide an out-of-the-box option to send alarms via HTTP. There is an option to forward alarms using TCP/IP sockets, but according to this question (Forwarding alarm events via TCP-IP sockets), this functionality will be phased out.
Both approaches you mentioned, using an Automation script or a connector, are valid. However, if you need to validate that the event was successfully delivered, handle failures, or implement retry logic, I would recommend using a connector, as it gives you more control over the communication flow.
Hope this helps.
