DataMiner DoJo
    • Empower Replay: Limited Edition
    • Sign up for the DevOps Pogram
    • All Partners
    • Strategic Partner Program
    • Deal Registration
Dataminer Maps – Using multiple TableFilter tags not working
Solved1.18K views18th July 2023Dataminer Maps
Alex Collantes [SLC]24 25th August 2021 1 Comment
Dear community,
I am having trouble using more than one TableFilter tag in the Maps Config file to filter rows in a table. Using a single tag seems to work fine, but 2 or more returns no matches for the search/filter.
Please see examples below:
(works)
(does not work)
When using only the top or only the bottom filter in the (does not work) example, the filter seems to work properly. I'm wondering if this issue could be related to using view tables? Am I doing something wrong? Is there a workaround for this?
Any help is appreciated. Thanks!
Marieke Goethals [SLC] [DevOps Catalyst] commented 18th July 2023
As this question has been inactive for a long time, we will now close it. If you still want further information, could you post a new question?
Alex Collantes [SLC]24 Posted 30th August 2021 0 Comments
Hi Wim,
Thank you for your help! Yes I did include the filterVars="myFilter" on the TableSourceInfo tag. And yes, the PIDs all belong to the same view table.
I want to emphasize that using any single filter seems to work every time, but 2 or more cause the search to break. Could this be an issue with maps when applying multiple filters to a view table?
Alex Collantes [SLC] Answered question 30th August 2021
