Data Aggregator DxM required licenses
Solved2.68K views23rd August 2024API Data Aggregator DxM GQI licenses
Robert Thevis [DevOps Advocate]300 31st August 2023 1 Comment
Hello everyone,
I have a question regarding licenses.
Assuming a customer wants to retrieve some data from DataMiner using a User-Definable API with Data coming from GQI using the Data Aggregator DxM.
What would be the minimal required licenses for this scenario? Could the Dashboards-License be left out if the Query was defined on another DMA and just imported to Data Aggregator DxM via the config File? Or does the Data Aggregator DxM itself require the Dashboards-License?
Best Regards,
Robert
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 23rd August 2024
I see that this question has been inactive for some time. Do you still need more information for this? If not, could you select Miguel’s answer to indicate that the question is resolved?
Robert Thevis [DevOps Advocate]300 Posted 31st August 2023 1 Comment
Hello Miguel,
yes I am planning to use both User Definable API and DataAggregator. I already tested it out locally and it works. It is just that the Customer might not have the money to spend on Reports & Dashboards, so I was wondering if it would work without that license. At the moment it isn't more than a bit of planning ahead anyway.
Best Regards,
Robert
Miguel Obregon [SLC] [DevOps Catalyst] commented 11th June 2024
Hi Robert,
About this question, as far as I know the Data Aggregator DxM does not require a license. Currently the only requirement is that the DMA is cloud connected (Data Aggregator can only be deployed through cloud services)
Hope it helps.
