Data Aggregator DxM required licenses
Solved2.70K views23rd August 2024API Data Aggregator DxM GQI licenses
Robert Thevis [DevOps Advocate]300 31st August 2023 1 Comment
Hello everyone,
I have a question regarding licenses.
Assuming a customer wants to retrieve some data from DataMiner using a User-Definable API with Data coming from GQI using the Data Aggregator DxM.
What would be the minimal required licenses for this scenario? Could the Dashboards-License be left out if the Query was defined on another DMA and just imported to Data Aggregator DxM via the config File? Or does the Data Aggregator DxM itself require the Dashboards-License?
Best Regards,
Robert
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 23rd August 2024
I see that this question has been inactive for some time. Do you still need more information for this? If not, could you select Miguel’s answer to indicate that the question is resolved?
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 31st August 2023 0 Comments
Hi Robert,
Small question not license related, is there a reason why the you would like to get the result of a GQI query through a User Definable API? The DataAggregator DxM allows you to execute the query remotely and export the result to:
  • A CSV file
  • Websocket connection
Or are you planning to use both 'User Definable API' + 'DataAggregator' to retrieve data from a DMA?
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 31st August 2023
