Dashboards – How can I select a switch first and then an interface via two dropdowns?
Solved2.78K views7th July 2023Arista Cisco Dashboard
8
Thomas Gunkel [SLC] [DevOps Enabler]1.23K 23rd January 2023 0 Comments
For a DataMiner Dashboard I want to create a dropdown to select a switch first and once selected I want to select an interface to show KPIs such as In Rate, Out Rate as well as Digital Optical Monitoring (DOM) parameters.
In the indices section I can only select by element or service, but not by protocol. Is there any trick to get the protocol?
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 7th February 2023 0 Comments
Hi Thomas,
The trick here is to use the complete data set of indices (you can drag/select the header of the indices data set to use it).
A small demo:
Sebastiaan Dumoulein [SLC] [DevOps Enabler] Answered question 7th February 2023
