Cube – View edit in Visio is not be saved in cube again
Solved2.07K views23rd January 2025Edit in Visio... Save View in Visio
Helmut Jung [DevOps Advocate]59 19th June 2024 3 Comments
Hi dojos,
It seems to be simple but I can not fix this problem. By using the "edit in visio..." function I can edit the drawing and by pressing the save button it get stored in a network folder but not on the DataMiner system.
How do I set-up Visio that it saves the edited drawing back on the system?
Thanks in advance and best regards,
Helmut
Miguel Obregon [SLC] [DevOps Catalyst] commented 19th June 2024
Hi Helmut,
When using the ‘Edit in Visio’ option, changes will be uploaded to the DMA after saving. In order to troubleshoot this issue, can you try the steps indicated in the question:
https://community.dataminer.services/question/visio-file-not-updated-when-edited-in-one-machine/?hilite=edit+visio
– Take a fresh start (you might have done this already, but just to be sure)
Close Visio and DataMiner Cube, then first start DataMiner Cube, choose ‘Edit in Visio’ (this should start ms Visio and open the correct Visio file), then do a little change in your Visio File inside ms Visio and hit save. This ‘Save’ should reload the file in DataMiner Cube
– Do you experience the same with Visio files assigned to Views?
– Did you check the logging in DataMiner Cube (System Center/Logging)? Is there anything like ‘Could not open in ms Visio xxx’
– Did it ever work before on that pc?
– Is this the initial Visio installation on that pc or did you recently upgrade?
– Did you try reinstalling ms Visio?
– Did you recently upgrade/install other office applications?
Marieke Goethals [SLC] [DevOps Catalyst] commented 22nd November 2024
Hi Helmut,
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select Pieter's answer (using the ✓ icon) to indicate that the question is resolved?
Marieke Goethals [SLC] [DevOps Catalyst] commented 23rd January 2025
Helmut Jung [DevOps Advocate]59 Posted 20th June 2024 0 Comments
Dear Miguel,
Within system settings I see the following path: \\file01\Home\hjung\Eigene Dateien\DataMiner Working Folder\Visio
There I see that DataMiner writes the drawing (4.8MB) and BAK (1KB)-file and I can open the drawing there including changes!
But Cube does not get updated!
To let you know, for IT-Security reasons I can not change macro settings and it is set to "Disable all macros with notification"
Any clue?
Thanks,
Helmut
Helmut Jung [DevOps Advocate] Answered question 20th June 2024
