Cube Offline Help
Solved2.23K views27th June 2023Cube
Tiago Dias [SLC] [DevOps Advocate]431 27th June 2023 0 Comments
Currently the default help option on cube, redirects to docs.dataminer.services.
This isn’t helpful on systems that don’t have direct access to internet. I recall in the past the help option was offline. Is there a way to control this with most recent DMA versions? For instance, via ClientSettings.json?
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 27th June 2023
Bert Vandenberghe [SLC] [DevOps Enabler]10.12K Posted 27th June 2023 0 Comments
Hi Tiago,
We no longer support offline help. That’s a choice we made, and I believe most people will have internet access these days. This way we are able to provide a better and more up to date help online. Advantages outweigh the disadvantages…
Bert
Baptiste Pattyn [SLC] [DevOps Advocate]5.86K Posted 27th June 2023 0 Comments
Hi Tiago
looking at this similar question (Offline version of DataMiner User Guide – DataMiner Dojo) I would say that this is not possible.
Baptiste Pattyn [SLC] [DevOps Advocate] Answered question 27th June 2023
