Cube loading speed decrease (eventually partly becoming unresponsive)
Solved735 views7th August 2026Cube Cube connected GUI frozen DM Cube
7
Nils Hoven [DevOps Advocate]1.83K 10th July 2026 1 Comment
We've experienced a decrease in loading speed of parameter values (element data in general) in tables and visuals, probably since the last DM update (or major Cube update). This varies and is not a exactly reproducible nor showing a constant behavior, but the overall experience is that the loading speed has gone down and the behavior is more laggy, especially after starting up Cube or opening a visual/table the first time in a session. Eventually this partly leads to Cube being unresponsive, just today this got much worse...
Anyone else experiences such issues in the last weeks?
Nils Hoven [DevOps Advocate] Selected answer as best 7th August 2026
Nils Hoven [DevOps Advocate] commented 10th July 2026
We're still in the process of investigating, but I assume this has been caused by excessive use of system resources, after creating a bunch of services / enhanced elements. After deleting these again the overall behavior seems to have normalized – so this probably is more of an individual issue than a general one. 🙂 :-/
Luís Freitas [SLC] [DevOps Advocate]1.12K Posted 7th August 2026 1 Comment
Hi Nils,
Thanks for raising this.
What you describe is generally expected when a DMA environment keeps growing over time (more services, elements, alarms, events, and overall load): Cube has more data to process and visualize, so responsiveness can gradually decrease in some views or workflows.
This can happen as the system scales and is not necessarily a sign of a fault in Cube itself.
However, if you’re experiencing a significant impact on daily operations, the best next step is to open a Skyline Support ticket. The team will then review your specific environment and determine if this is normal scaling behavior or an issue that needs to be addressed.
Nils Hoven [DevOps Advocate] commented 7th August 2026
Hi Luís,
thanks a lot for your feedback!
As I mentioned in my comment above already (and this was confirmed within the days that followed), in this case the behavior was related to the creation of services using a custom tailored service protocol as well as some issue manifesting itself in case a child element of said services is hosted by the same DMA – this is currently under investigation by Robin Meurisse.
Anyway, reaching out to support indeed helped a lot – shoutout to everyone involved! 🙂
