Cube – define a default View
Solved808 views12th September 2025alarme console root-view
Simon Nenez [DevOps Advocate]756 26th May 2025 2 Comments
Dear Dojo,
On Cube i want to defined a default view diferent than the Root View.Because currently when I close all the opening cards, my alarm console "actives linked to cards" will load all the alarms as I clicked on the root View.
I don't want that because each time i closed all the cards it introduced a big latency and loading period to display all the alarms on the "actives linked to cards" alarm console.
Thanks for your help
Simon
Miguel Obregon [SLC] [DevOps Catalyst] commented 26th May 2025
Hi Simon,
Maybe an option could be using workspaces?
https://docs.dataminer.services/user-guide/Getting_started/The_DataMiner_User_Interface/DataMiner_Cube/Working_with_workspaces.html
Simon Nenez [DevOps Advocate] commented 26th May 2025
Hi Miguel,
This is what I've done, when they open Cube a Site View is loaded by default. But when they close the card corresponding to this view, so 0 cards are present, the active linked to cards alarm console is filling with the alarms of all the DMS (more or less like an Active alarms alarm console)
Michaël Pincket [SLC] [DevOps Advocate]1.96K Posted 28th May 2025 0 Comments
Hi Simon,
Currently it is not possible to set a default view which is not the Root View.
We will take a look to see what is causing the latency and provide a fix for it.
