Cube automatically connect to alternate DMA if connection to Primary is lost
Solved1.31K views12th July 2023
Chris Glover [DevOps Advocate]2.17K 8th November 2022 0 Comments
Is it possible to specify a backup connection in Cube, in the event that the connected DMA goes away (e.g crash, failover etc), Cube can attempt to connect to another specified DMA in the same system automatically?
If not, please add as a feature request.
Thanks
Baptiste Pattyn [SLC] [DevOps Advocate]5.86K Posted 17th January 2023 0 Comments
Hi Chris
thank you for reaching out to us. At the moment this is not possible in Cube. I will present this feature request internally.
Wkr,
Baptiste Pattyn
