credentials when using the Chromium engine
Solved2.83K views19th July 2023video thumbnail Visio Visual Overview
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 22nd December 2020 2 Comments
In a visual overview, we have a video thumbnail with as source files stored on the DataMiner server (accessible to IIS).
Since the upgrade to DM10, the Visio seems to ask for the credentials to load the thumbnail each time the card is opened.
It didn't do this before the upgrade.
Is there a way to have these credentials saved?
If that's not possible, can we use a user with limited rights and predefine the thumbnail to use these credentials?
José Spetebroodt [SLC] [DevOps Member] Answered question 19th July 2023
Wim Bruynooghe [SLC] [DevOps Advocate] commented 22nd December 2020
Cube should take care of the authentication (it should include an http-header with an authentication token of the currently logged-in user when requesting the videothumbnails webpage). If you get a login popup then something went wrong. This should get further investigated by our Cube software development team.
PS: The values of the url parameters (like type, source, etc) should actually be url-encoded.
Jeroen Geldhof [SLC] [DevOps Enabler] commented 4th February 2021
An issue was found and fixed.
RN28782
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K Posted 22nd December 2020 1 Comment
Hi Jeroen, can you try adding user credentials to the URL like below? It's recommended to set up a dedicated user with very limited rights for this.
http://user:pass@<DMAIP>/VideoThumbnails/...
Wim Bruynooghe [SLC] [DevOps Advocate] Edited comment 22nd December 2020
This is not recommended and could lead to a security threat, as this puts a user&pass visible for any DataMiner user and these credentials could leak out as it’s not even send over a secure connection…
Instead, Cube should take care of sending an http header with an authentication token of the current logged-in user in Cube.
