Credentials Management for Dataminer Automation Script Solution
Solved2.81K views30th September 2024
Ramesh Rajasekaran [DevOps Advocate]978 10th July 2024 4 Comments
Currently, I am storing the credentials in an XML file and consuming them in the code. But I don't want to store the credentials in XML due to security reasons.
Is it possible to store the credentials in the Windows credentials store and fetch them in code? Is it possible to access the Windows credentials store from a data miner?
Also, please suggest if there are any other better options to store and fetch the credentials to improve security.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th September 2024
Ramesh Rajasekaran [DevOps Advocate] commented 10th July 2024
I am using dataminer automation scripting solution
Rebecca Kelsall [DevOps Advocate] commented 10th July 2024
I am not sure using Windows Credentials is a good option because it would rely on that server available or for it to be configured on the entire cluster. Does anyone know of a secure way to save them within Dataminer, either by a configurable hidden parameter in the XML or are people building a driver to encrypt and to store them?
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th August 2024
Hi Ramesh,
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th September 2024
As this question has now been inactive for a long time, I will close it. If you still want more information about this, could you post a new question?
Jon Corral [SLC] [DevOps Member]464 Posted 10th July 2024 0 Comments
Hello Ramesh,
Some weeks ago I posted a similar question in Dojo. In my case, I wanted to move the credentials from the code to somewhere safer and providing better privacy. The answer I got could help you. As far as I know, there is no way right now of storing them in Dataminer.
AdHocDataSource - UI or option to pass some input parameters that are hardcoded and sensible - DataMiner Dojo
Jon Corral [SLC] [DevOps Member] Answered question 10th July 2024
