CPU usage on Virtual Infrastructure for DMA
Solved2.23K views18th October 2023cpu usage Virtual Infrastructure virtualization
Richard Henderson196 17th October 2023 0 Comments
From reading the documentation on using virtual infrastructure there is a section that states.
Make sure you assign enough CPU power to keep the CPU usage under 50%
Now is that 50% average or 50% max for a stated period of time as it does not go into details?
Currently have a DMA which spikes above 50% max a number of times per day and it not really loaded up with elements.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 18th October 2023
Bert Vandenberghe [SLC] [DevOps Enabler]10.12K Posted 17th October 2023 1 Comment
Hi Richard,
It's more referring to the average. It's no problem to go above 50% now and then. You should just make sure you have sufficient margin on the DMA for client requests and occasional actions on the DMA.
Bert
Marieke Goethals [SLC] [DevOps Catalyst] Posted new comment 18th October 2023
Marieke Goethals [SLC] [DevOps Catalyst] commented 18th October 2023
I’ve adjusted the documentation so this will be clear now. https://github.com/SkylineCommunications/dataminer-docs/pull/2139/files
