Correlation – Why can’t I create correlation rules for a hidden element?
Solved2.03K views16th February 2022Correlation
Jens Vandewalle [SLC] [DevOps Advocate]10.07K 3rd February 2022 0 Comments
I want to create a correlation rule to investigate something that is going on with IDP solution element DataMiner IDP Configuration. Strange thing is that I'm not able to create my correlation rule as long as the element is hidden. What is the reason for that?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 16th February 2022
Wouter Demuynck [SLC] [DevOps Advocate]7.08K Posted 8th February 2022 0 Comments
I don't really see a reason why Correlation rules should not work just as fine if one of the elements involved is hidden.
What I assume is going on here is that the Cube UI does not allow to select these elements (as it tries to hide these elements by default)
Wouter Demuynck [SLC] [DevOps Advocate] Answered question 8th February 2022
