Correlation – Why can’t I create correlation rules for a hidden element?
Solved2.00K views16th February 2022Correlation
Jens Vandewalle [SLC] [DevOps Advocate]10.00K 3rd February 2022 0 Comments
I want to create a correlation rule to investigate something that is going on with IDP solution element DataMiner IDP Configuration. Strange thing is that I’m not able to create my correlation rule as long as the element is hidden. What is the reason for that?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 16th February 2022
Pieter Van Compernolle [SLC] [DevOps Enabler]4.39K Posted 16th February 2022 0 Comments
In the meanwhile, seems like one of the Cube squads did a small change in order to make this possible from 10.2.4 onwards (also in main release 10.0.0 CU22 – 10.1.0 CU13 – 10.2.0 CU1).
(internal ID: 32510)
Wouter Demuynck [SLC] [DevOps Advocate]7.04K Posted 8th February 2022 0 Comments
I don’t really see a reason why Correlation rules should not work just as fine if one of the elements involved is hidden.
What I assume is going on here is that the Cube UI does not allow to select these elements (as it tries to hide these elements by default)
Wouter Demuynck [SLC] [DevOps Advocate] Answered question 8th February 2022
