Correlation rule – When there is more than 10 alarms – Group by element
Solved2.54K views18th July 2023Correlation group
Laurine Renard20 15th September 2021 0 Comments
Dear Dataminer Dojo,
In the correlation rules, I was wondering if it is possible to add in this following condition :
- When we have more than 10 alarms on one element, I would like to group those alarms.
I have tried to add the Rule Condition, with count(*) < 10, however it is not related to one element and I wasn't able to group by element in the Rule Condition.
If any one has an idea, do not hesitate.
Thanks in advance,
Laurine
Ben Vandenberghe [SLC] [DevOps Advocate]9.76K Posted 15th September 2021 2 Comments
Hi Laurine, your first step would be to group incoming alarms by element.  Because the evaluation is then done on an element basis.  Can you make sure that this is set up like this at the top of your correlation definition?
Wouter Demuynck [SLC] [DevOps Advocate] commented 16th September 2021
as a note: don’t enable the “trigger on single events” checkbox for this rule, as it will not keep track of the active alarms per elements if you do.
Ben Vandenberghe [SLC] [DevOps Advocate] commented 16th September 2021
Correct Wouter, well-spotted. Apologies for that, I just wanted to depict the drop down with the selection of that specific ALARM GROUPING option. Thanks!
