Client side ports in CUBE: how many are open during a connection to a DMA?
Solved290.67K views17th March 2026adl2099 client ports eventing netstat
6
Alberto De Luca [DevOps Enabler]5.75K 17th February 2023 4 Comments
Please, Dojo - I'm trying to detail the exact behaviour of a CUBE client connecting to a DMA via
.NET-Remoting>Eventing (this to facilitate FW configs).
On connection to a DMA, I seem to get at least one connection established, however the client switches to polling mode.
The output of a netstat on the client would show something like this:
It seems the ports in the "high port range"  (49152 through 65535) are allowed on the client - the connection is actually "ESTABLISHED" to port 8004 of the server - via client port 51134, but then why the client has a second connection open in "TIME WAIT" and eventually switches to polling?
Is more than one port required on the client for eventing?
Or could the server be configured to use polling regardless of the connection successfully established between client port 51134 and server port 8004?
Cube settings for the above test were like this:
Any steer will be helpful
Jim Hugelier [SLC] Changed status to publish 17th March 2026
Marieke Goethals [SLC] [DevOps Catalyst] commented 7th July 2023
Hi Alberto,
I see that this question has been inactive for some time. Have you found a solution for this yet? If yes, could you share some more information about this, and select the best answer (using the ✓ icon)? If not, you can also contact techsupport@skyline.be for assistance.
Alberto De Luca [DevOps Enabler] commented 26th July 2023
Need to resume testing on this – I seem to have different numbers of connections depending on the environment – I will update the thread as soon as I gather some more data
Marieke Goethals [SLC] [DevOps Catalyst] commented 23rd August 2024
Hi Alberto,
I see that this question has been inactive for a long time. Do you still need more information about this? If not, could you select the best answer to indicate that no further action is needed here?
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th September 2024
Rene De Posada [SLC] [DevOps Advocate]1.94K Posted 18th February 2023 1 Comment
Alberto,
You can configure Cube to only use polling see (Eventing or polling | DataMiner Docs). This is less performant but should align with what you are trying to achieve if I understand correctly?
Alberto De Luca [DevOps Enabler] Edited comment 20th February 2023
Alberto De Luca [DevOps Enabler] commented 20th February 2023
Thanks, Rene
We’re trying to move away from this set-up, as clients don’t seem to cope very well while handling the polling required to handle alarms during storms.
Long story short, I believe this was a shortcut that was used when the monitored network was sufficiently small, but it is way bigger now, so we’d rather restore the eventing mechanism as the default behaviour, so that the load on the server doesn’t increase linearly (on SLNet) with the number of connected clients.
You are viewing 1 out of 8 answers, click here to view all answers.
