Children rows unsorted after element restart
Solved1.03K views7th November 2023Visual Overview
Robin Becker [DevOps Member]1.42K 6th November 2023 2 Comments
We have a problem where we have a visual overview which shows data based on rows in a table and if we restart the element containing the table then when the element comes back up a repopulates the table, the rows in the visual overview are in the wrong order.
Right now the only fix is manually closing and re-opening the visual overview but I'm wondering if there is a better way of having the visual overview re-populate the children rows in the correct order at element restart?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 7th November 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 6th November 2023
Are you using a ‘ChildrenSort’ shape data?
Robin Becker [DevOps Member] commented 6th November 2023
Yes, based on a TableColumn
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.45K Posted 6th November 2023 0 Comments
Hi Robin,
We were able to reproduce this as well. A task has been opened to tackle this issue and we will post an update here once it has been resolved.
