Child Element / Input data
Solved1.34K views26th August 2024#childelement #inputdata #visiodashboards
Juan Chavez514 7th May 2024 0 Comments
Hello @here DM forum,
Im relatively new to dataminer and currently in learning/deployment phase. Have couple questions. Does anyone know when creating a template, whats the difference in child elements and input data. Seems they go hand in hand. Where Im confused is why some devices I have to select input user text and in one particular device i need to select table row index.
here are my conditions and devices
Im creating a service for Evertz products (IPG, VIPs, service name) from that service template im creating a visio dashboard but seems if I dont configure child and input data correctly doesn’t seem to create a visual.
Why do i need to configure my VIP to see table row index and not service name?
whats the difference between
  1. Allow element to be reused by multiple services
  2. This service child is optional
  3. Include all matching elements in generated service
Any information is greatly appreciated
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 26th August 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 7th May 2024 1 Comment
Hi Juan,
Please find below some answers to your questions:
When creating an input data you have three possible options: ‘User Input Text’, ‘Table Row Index’ and ‘Fixed Value’.
‘User Input Text’ is used when you plan to create services from a CSV file. In this case the input data will be a column in the CSV file.
‘Table Row Index’ is used when you plan to pass a value from a parameter (in an element) to generate the service.
Could you elaborate a bit more on this question? If I understand correctly, you would like like to generate services from the element monitoring the VIP. Is it correct?
You can more information about these options in DataMiner Docs.
Hope it helps.
Juan Chavez commented 28th May 2024
Thank you @Miguel Obregon, wasn’t sure what the difference was exactly, appreciate the detailed explanation.
Regards,
Juan
