ChatOps (Teams bot) – Is it possible to create a custom command with an input parameter?
Solved2.83K views20th April 2023ChatOps custom command teams bot
Bruno Dias [SLC] [DevOps Member]2.37K 20th April 2023 0 Comments
If yes, can you please let me know how can I make it?
My goal is to get a parameter value in real-time using the MS Teams bot.
Bruno Dias [SLC] [DevOps Member] Selected answer as best 20th April 2023
Jordy Ampe [SLC] [DevOps Advocate]2.00K Posted 20th April 2023 0 Comments
Here we provided some examples with different kind of inputs/outputs:
ChatOps-Extensions/CustomCommandExamples at main · SkylineCommunications/ChatOps-Extensions (github.com)
