Cassandra Monitor System checks
Solved3.08K views27th March 2025Cassandra Cassandra Reaper
Felix Wesemeier [DevOps Catalyst]2.54K 23rd April 2024 3 Comments
Hi community,
I tried to monitor a 3 nodes Cassandra cluster with the "Apache Cassandra Cluster Monitor" driver version 1.0.2.2
The System Checks table shows two warnings for all three nodes:
1. Repair Needed, Warning, "The tables 'partition_denylist', 'view_build_status' were not repaired within the tombstone removal period. Please increase the gc_grace_seconds or the frequency of the repairs. Repair checks for specific tables can be disabled in the Tables table."
Cassandra-Reaper is running and blacklistTwcsTables is set to true. So everythings is running in auto mode. What should I do, simply disable the check for this 2 tables?
2. Server Encryption, Warning, When your nodes communicate over a zero trust network, it is best to enable inter-node encryption (server_encryption_options_enabled, server_encryption_options_internode_encryption, server_encryption_options_endpoint_verification). For more information on how to enable it go to below link.
I think inter-node encryption is running fine. What is expected in the config file?
My settings:
server_encryption_options:
internode_encryption: all
optional: false
legacy_ssl_storage_port_enabled: false
keystore: ...
keystore_password: ...
require_client_auth: false
truststore: ...
truststore_password: ...
require_endpoint_verification: false
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th March 2025
Felix Wesemeier [DevOps Catalyst] commented 23rd April 2024
Additional question:
Dataminer shows me that one not is not available “Cassandra cluster health is yellow. DataMiner is still fully functional. 1 out of 3 Cassandra nodes are unavailable: ………..:9042.”
But the Cluster monitor driver works fine with this node and I can connect with DevCenter too. What could be wrong?
Felix Wesemeier [DevOps Catalyst] commented 24th April 2024
Regarding the 2nd question:
It looks like Dataminer expects require_endpoint_verification = true.
If I set it to true I can only reach each cassandra node locally and got cassandra errors like ” No subject alternative names matching IP address 192.168.2.162 found”. But they are specified in the cert (each keystore contains all 3 nodes with SAN and the rootCA).
How to debug?
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th September 2024
Roger Andreasson [DevOps Advocate]930 Posted 15th October 2024 1 Comment
We have the exact same issue with Cassandra cluster monitoring showing those two tables as "repair needed". We have run a nodetool repair -full. Wouldn't that repair those tables as well?
Michiel Saelen [SLC] [DevOps Advocate] Posted new comment 16th October 2024
Michiel Saelen [SLC] [DevOps Advocate] commented 16th October 2024
It will depend on how your cluster looks like, the RF etc. nodetool repair -full will initiate a repair from the node on which you run the command for all token ranges that should be available on that node. So if you have more nodes then you RF, not all data will be repaired running it from one node. Important is that you don’t trigger a repair for the same token range on more than one node at the same time as Cassandra does not handle this well. That is why Cassandra Reaper was created to handle that for you.
