Can we monitor the Evertz NAT X switch with two NIC IPs (primary and secondary ports) in Dataminer?
Solved1.32K views28th March 2025ben squad.deploy-espresso@skyline.be
Aejith Antony [DevOps Member]92 26th August 2024 4 Comments
We prefer not to add the two NIC IP addresses as separate individual elements for the device. Instead, we require a single element that displays the status of both NICs within it. is that possible ?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th March 2025
Miguel Obregon [SLC] [DevOps Catalyst] commented 26th August 2024
Hi Aejith,
Can I ask why you would like to avoid creating two elements? What potential issues/constraints do you anticipate with using two elements?
Is it not an option to use redundancy groups?
https://docs.dataminer.services/user-guide/Basic_Functionality/Redundancy_Groups/RedundancyGroups.html
Aejith Antony [DevOps Member] commented 26th August 2024
Hi Miguel,
To clarify, we have two NIC ports with different IP addresses on the same DTH-A NATX device: DTH-A-NIC 1 and DTH-A-NIC 2. If we set them up as separate elements, we’ll end up polling the same data twice from the same device.
We want to avoid this by implementing network redundancy monitoring. The goal is to have only one IP polled at a time. If the primary IP isn’t responding, the secondary IP should take over. If neither IP is working, it should show a device communication error. for this scenario redundancy groups option will work?
Marieke Goethals [SLC] [DevOps Catalyst] commented 23rd January 2025
Hi Aejith,
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select the answer (using the ✓ icon)?
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th March 2025
Miguel Obregon [SLC] [DevOps Catalyst]23.73K Posted 26th August 2024 0 Comments
Hi Aejith,
Based on your use case, an option could be using redundant polling.
Hope it helps.
