Can I use dataminer for PTP monitoring? if yes, how it is helpful?
Solved4.47K views27th January 2023broadcast PTP
pramod Gupta [SLC] [DevOps Member]277 5th August 2020 0 Comments
Is it possible to trace the PTP using dataminer? If yes, is there any recommendation of specific PTP generators? What kind of PTP generators are already integrated with dataminer, if any?
Jens Vandewalle [SLC] [DevOps Advocate] Answered question 27th January 2023
Thomas Gunkel [SLC] [DevOps Enabler]1.25K Posted 6th August 2020 1 Comment
Hi Pramod,
Please find below the products that are currently supported. As Ben stated, any other PTP node can be added at any time.
  • PTP grandmaster clocks
    • Tektronix SPG8000
    • Meinberg Lantime M3000
    • Evertz 5700MSC
  • PTP boundary/transparent clocks
    • Cisco Nexus 9000 series
    • Arista 7000 series
  • PTP analyzers
    • Tektronix Prism
  • PTP slave clocks
    • Imagine SNP
    • Lawo Nova HD Core
    • Lawo Powercore
    • Ross Newt
pramod Gupta [SLC] [DevOps Member] Posted new comment 8th September 2020
pramod Gupta [SLC] [DevOps Member] commented 8th September 2020
Thanks Thomas, it really helps.
