Can (how to) an Automation script run in c#8.0?
Solved1.47K views13th August 2024automation scipt
Mieke Dryepondt [SLC] [DevOps Advocate]4.19K 12th August 2024 0 Comments
  1. Can an Automation script run in c#8.0? When I now check the language version of the Script project via DIS I see it is set to 7.3
  2. How to change it?
I’m running DataMiner version 10.4.9.0-14678
Laurens Vergote [SLC] [DevOps Member] Answered question 13th August 2024
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 12th August 2024 0 Comments
From the documentation, it seems only c# versions up to (and including) version 7.3 are supported.
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 13th August 2024
Laurens Vergote [SLC] [DevOps Member]368 Posted 13th August 2024 0 Comments
If you’re referring to the C# language version, then Automation is indeed capped at version 7.3 since we compile the code with the .NET Framework target.
If you’re referring to the .NET version, then also no. We currently don’t support code in automation scripts to be compiled with anything but the .NET Framework target.
