Bypass CRL check in DataMiner
Solved1.15K views28th April 2026CRL
Roger Andreasson [DevOps Advocate]986 16th April 2026 0 Comments
We use Cube Laucher in a managed VDI environment to access DataMiner.
After upgrade to 10.5 CU10 we get the CRL check error because the VDI environment does not have internet access. Since the VDI environment is managed (meaning we can't easily change settings), the best avoidance option would be throgh the DataMinerCube.exe.config workaround described here:
DataMiner Cube freeze on startup | DataMiner Docs
The problem is that we've tried placing the file both in the laucher directory and the directory for the specific Cube version for that DMS
...\AppData\Local\Skyline\DataMiner\DataMinerCube
...\AppData\Local\Skyline\DataMiner\DataMinerCube\DataMiner Cube\Versions\10.6.2547.3014
but it doesn't work, we still get the annoying 20 second delay and the popup.
Any idea why?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th April 2026
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 24th April 2026 1 Comment
Hi Roger,
There are 3 workarounds mentioned in the docs.
for workaround 2 (prevention) , it is advised to have no Cube sessions open when applying.
You need to create and place the config file ""DataMinerCube.exe.config where the DataMinerCube.exe file is located.
Small note: you need to do this for every new version.
So this is now done for "10.6.2547.3014", assuming this is the active used Cube version.
Besides that, would it be possible to also try workaround 1 (compliance ) and workaround 3 (mitigation)? If possible to contact your IT department or admin.
Hope this helps you further
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th April 2026
I have been informed that this issue has now been resolved. Putting DataMinerCube.exe.config in the main DataMinerCube folder solved the issue; however, it is important to ensure that the file extension is shown, as otherwise the file could be renamed to DataMinerCube.exe.config.txt.
Roger Andreasson [DevOps Advocate]986 Posted 24th April 2026 0 Comments
Yes, we have put it in the correct version directory where the DataMinerCube.exe file is located (10.6.2547.3014)
Roger Andreasson [DevOps Advocate] Answered question 24th April 2026
