Better way to delete rows
Solved2.24K views22nd November 2024protocol.DeleteRow rows
Sergio Suarez [SLC] [DevOps Member]123 1st August 2024 1 Comment
Currently, the driver is deleting a part of the total rows at once, which is taking too much time and causing an RTE to pop up. We have already logged the times and the amount of rows to be deleted:
As you saw, the amount of rows to be deleted is over 50,000.
The way we are doing it is:
protocol.DeleteRow(Parameter.Cmqamdschannels.tablePid, keysToRemove);
My question is if there is another way to delete rows so it won't stay a lot of time doing it.
Thanks.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 22nd November 2024
Edib Šupić [SLC] [DevOps Enabler] commented 2nd August 2024
Hi Sergio,
since you are removing all rows, would protocol.FillArray with empty array speed things up?
Michiel Oda [SLC] [DevOps Advocate]3.90K Posted 2nd August 2024 1 Comment
Hi Sergio
When you want to clear the entire table, the most efficient would be to use the Action clear in the XML: clear | DataMiner Docs
If you are in a QAction, you can call 'protocol.CheckTrigger(id);'. Then have a trigger with that id that triggers that Action. This way you don't need to retrieve all the keys in the QAction.
Sergio Suarez [SLC] [DevOps Member] Posted new comment 5th August 2024
Sergio Suarez [SLC] [DevOps Member] commented 5th August 2024
Hi Michiel,
I think I wasn’t clear with my question. I am not trying to delete all rows nor clear the full table; I am trying to delete some rows.
As you can see in the screenshot, the number of rows obtained is the total of the rows in the table, while the number of rows to be deleted is less than the first value.
Sorry for the misunderstanding.
